Hello I have a 2016 Viper lx dx. Only 3000 km. I just replaced my battery. I have always had the Viper start blues but it has always started. I have the lastest flash. I bought a new battery in December. When my sled is cold it wont fire up. Cranks until the battery weakens but no fire. Brought the battery back the beginning of January they said it was defective. They gave me another. Tried the new one same issue. I put my meter on it. When battery is cold sitting overnight it shows 12.2 volts. While trying to crank the voltage drops to 7.2 ish. After I boost the sled with my battery booster its showing 14.2-14.4. I brought the battery back they load tested it and said the battery was good. I think its the battery again. But have to have a reason . The battery states 230cca. Any ideas would be appreciated.
Sounds like you may have relay issues. Do you hear the fuel pump cycle when you turn the key to on?
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I'm going to guess starter issue after recently reading several threads on people replacing the OEM starter and how well it starts afterwards. Here's one on hot start issues: https://ty4stroke.com/threads/hot-starting-troubles.164302/post-1581372
Or maybe plugs: Thread 'SR Viper XTX Will Not Start' https://ty4stroke.com/threads/sr-viper-xtx-will-not-start.164254/
Yes I do here the fuel pump cycle with the key on. Thank you.Sounds like you may have relay issues. Do you hear the fuel pump cycle when you turn the key to on?
Angelo
- Sep 5, 2020
- Saskatchewan
- 2016 Yamaha Viper 153 w/ MPI Turbo
This seems to be a somewhat common issue for some. I’m no different and frustrated. Just picked up my sled from the shop yesterday. 2014 viper xtx. It sat in a heated shop all week was good and warm. Went to start and it just cranked and cranked and cranked and finally started up. This has been the case with this sled ever since I bought it 3 years ago. New battery didn’t solve anything. It’s just a real bitch to start. Once it starts and is warm there are no issues with starting after that. But that first starts is always just brutal. I’ve read replace plugs, injectors, Seafoam, fuel? Fuel pump always kicks in when key is turned. Any solutions to this or just a process of elimination.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I am working a 2014 ZR 7000 with the same issue. It is going to the dealer soon to see if it has the latest flash. After that ????
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
I thought I heard that after a while valve clearance needs to be checked, and if adjustment is needed, it can cause "hard to start" conditions.
Check the alignment of the crank sensor mark with the shorter tooth which is located on the backside of stub shaft.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Check your valve clearance. Tight exhaust valve clearances will cause hard cold starts but will start normal when engine is warmThis seems to be a somewhat common issue for some. I’m no different and frustrated. Just picked up my sled from the shop yesterday. 2014 viper xtx. It sat in a heated shop all week was good and warm. Went to start and it just cranked and cranked and cranked and finally started up. This has been the case with this sled ever since I bought it 3 years ago. New battery didn’t solve anything. It’s just a real bitch to start. Once it starts and is warm there are no issues with starting after that. But that first starts is always just brutal. I’ve read replace plugs, injectors, Seafoam, fuel? Fuel pump always kicks in when key is turned. Any solutions to this or just a process of elimination.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
The sled I am helping with at has only 1400 miles on it. The speedo is off also.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
I remember hearing that some sleds that were reflashed had speedo issues afterwards due to not being flashed with correct model info. There is a difference in track driver size between some models and if proper flash was not installed it would result in speedometer being incorrect
