We have about 75 rear wheel kits shipping out on Thursday. Thanks for your patients guys. Happens every year but this year we got them early. We will have lots of the heavy duty stealth kits in stock from here on out. All our kits are anodized black with lifetime warranty on the aluminum parts. J&T 's Stealth kits and trihub kits use a much larger diameter axle. We use the larger bearings on all out kits except the add on 4th wheel kits.
We have both sizes Trihub replacement kits ready to go.
Add on 4th wheel kits in 5 colors.
Snopro 500-600 and 2013 RR model kits also ready to go.
Firecat kits
We are ready for the snow!!
Firecat kits
Update: Will ship Friday.
Just bought the RR kit. Will be nice being able to adjust track easier!
We had to take the nut out of the axle because some of the racers were able to break the axle in half. the 3/8 nut took to much material out of the 1 inch diameter axle and made it the weak spot. if you have a 13 RR you can buy the plastic spacers from the newer RXC models and the spacer has a pocket to hold the nut. The plastic spacers are cheap to buy.Just bought the RR kit. Will be nice being able to adjust track easier!
Oh man! I have those already. They suck. Nuts spin. Change your website! But thanks for the warning here. I will get new plastic ones from cat.We had to take the nut out of the axle because some of the racers were able to break the axle in half. the 3/8 nut took to much material out of the 1 inch diameter axle and made it the weak spot. if you have a 13 RR you can buy the plastic spacers from the newer RXC models and the spacer has a pocket to hold the nut. The plastic spacers are cheap to buy.
- 7K
