sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Didn't have any steam coming off, but I was not riding in as cold a weather or deep of snow.
It does give off a lot of heat though. My buddy figured out that the little grate right in front of the handlebars has a lot of heat coming out of it and was using it to warm his hands every time we stopped. Great place to leave your helmet too.
Harleywarden
- Dec 15, 2013
I will lift it and check it out
Harleywarden
- Dec 15, 2013
cannondale27 said:Its probably because the exhaust shield is not sealed especially right by chaincase. Lots of steam can come through there. I will probably get something like Silicon sheet material and seal that off.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
sxr70001 said:Didn't have any steam coming off, but I was not riding in as cold a weather or deep of snow.
thats also where Cat puts its "heated google bag" accessory. There must be some warmth there!
Harleywarden
- Dec 15, 2013
how do i post a photo on this site?
wot-75
Harleywarden said:how do i post a photo on this site?
I think the usual problem is file sizes are too large.
Use this website to resize your photo and then click the "add an attachment" button.. etc.
http://www.picresize.com/
Harleywarden
- Dec 15, 2013
the way they have designed the exhaust to run under the tunnel for cooling and not sealing/shielding it off from the engine compartment is going to cause huge problems when running higher speeds and in powder when its nail biter cold. Like i did on a river run last Saturday. I have some pics but i am not sure how to post them here. will always cause the steam to rise through the entire hood/vents/goggle warmer and coat the sled and yourself/visors/goggles with a frost layer. not impressed with this. is there or will there be a fix?
Harleywarden
- Dec 15, 2013
wot-75 said:Harleywarden said:how do i post a photo on this site?
where is there an attachment button, looking all over
Studroes144
You have to click post reply. You can't do it on the quick reply option
Harleywarden
- Dec 15, 2013
Harleywarden
- Dec 15, 2013
guys let me know your thoughts on this please??
Yamadog
After years of riding crap that loaded the tunnel full of block ice I will take the little amount of steam coming up through the radiator opening. Remember you now have a front mounted radiator, a front discharge exhaust so all the heat is loaded where the snow goes. Mine only steams when I stop SO DON'T Stop
As far as temps don't look at the bar graph read the actual temp #'s that's what it is there for
Harleywarden
- Dec 15, 2013
Yamadog, i was riding with three others and none had this problem. they all felt this is strange and were not impressed. yes they were riding diff sleds, but i didnt pay what I did to have sled steam like that through all vents of the hood. next time it happens i will be posting pics.
09nytro
I'm thinking you are the only one that is having this problem so far , maybe the heat shield is bent or not mounted right !
wot-75
09nytro said:I'm thinking you are the only one that is having this problem so far , maybe the heat shield is bent or not mounted right !
I'm thinking he's the only one running through super sloppy wet stuff at -18.4F
