Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Mine as well and my friends cat as well.My 2016 Viper was delivered like this also.
Carla 123
- Feb 27, 2017
- Lester beach
Glad you got it .just like the track alignment I gave up with the bs and just going to do what I bought it for.ride the fing thing
Snowmobile Mike
- Oct 19, 2018
- East Haven Connecticut
- 2016 Yamaha XT SE
So it wasn't bent , Obviously it got delivered from dealer that way ! Dropped at my friend's today who is a guru MECHANIC ! I also picked it up, PROBLEM Not Bent , misaligned ! It was off over 1 1/4 inches he did his thing with straight edges and laser and adjustments and it's good to go ! I could have done it but I certainly wouldn't have been done today, happy to give him a few bucks and now it's DONE ! Can't believe the type of workmanship these days , OH on second thought yes I Can ! Thanks guys for all your help ! And the thing is although we should check all things out ! You really shouldn't HAVE TO , might as well tell them deduct some set up fees and We'll get it done and pay a trustworthy MECHANIC ! ! !
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
Look at all the experience I'm, we're getting ! ! !
I don't need it man !
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
When you own a sled, these are the trials that force you to get familiar with them mechanically. The more things that you do yourself, the better you know the machine.Look at all the experience I'm, we're getting ! ! !
I don't know the dealer that you dealt with, and I'm not going to try to defend them but its possible that someone else had the tie bars out of place. If you dont have a reason to check, you could've ridden it for years without knowing there's a problem.
Good luck and enjoy your new sled!!!
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
True you really dont know ! BUT this sled has only 125 miles ! ! !When you own a sled, these are the trials that force you to get familiar with them mechanically. The more things that you do yourself, the better you know the machine.
Snowmobile Mike
- Oct 19, 2018
- 2016 Yamaha XT SE
Any Snow in Canada !True you really dont know ! BUT this sled has only 125 miles ! ! !
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Nope, I could rake leaves right now...Any Snow in Canada !
Allan
Need to move down east I have 1500km on sled this year so far. pic's was taken last weekend
YamahaHoss
I hit a tree with my RS Venture TF 2015, and besides the front end damage--I think I sorung the steering column because my upper body panel up past the gas tank is not sitting correctly now after the accident? WHere do you think it might have bent just enough to move that panel? Or how can I really tell?My guess is below the riser. From the riser mount to the top mount of the column. It could have been rolled on its side.
YamahaHoss
I hit a tree with my RS Venture TF 2015, and besides the front end damage--I think I sorung the steering column because my upper body panel up past the gas tank is not sitting correctly now after the accident? WHere do you think it might have bent just enough to move that panel? Or how can I really tell? ALso--do I have to remove the motor if the steering column is bent? (down by the bulkhead--the tie rod ends now rub on the right side of the engine block--although I know the spindle is 15/16 in pushed back on the top which would have pushed the tie rod ends back...) )Bent column from the mount up? I have seen this before.. easy repair.
YamahaHoss
Does anyone have experience with fixing a bent steering column? how to remove? do I need to take out the engine? ANY help would be great for my 2015 RS Venture TF that met a treeIn parts schematic from Yamaha which part are you talking ?
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
You'll have more luck posting in the RS Venture forum. This is for SR Viper owners. Good luck.Does anyone have experience with fixing a bent steering column? how to remove? do I need to take out the engine? ANY help would be great for my 2015 RS Venture TF that met a tree
YamahaHoss
Thank youI hit a tree with my RS Venture TF 2015, and besides the front end damage--I think I sorung the steering column because my upper body panel up past the gas tank is not sitting correctly now after the accident? WHere do you think it might have bent just enough to move that panel? Or how can I really tell? ALso--do I have to remove the motor if the steering column is bent? (down by the bulkhead--the tie rod ends now rub on the right side of the engine block--although I know the spindle is 15/16 in pushed back on the top which would have pushed the tie rod ends back...) )
