- Apr 14, 2003
- Hessel, Michigan
Not to create havoc....but I installed my new charge tubes from Evolution Powersports last night and the stock charge tube clamps were barely holding in 2 spots. When I mean barely, I'm talking the clamp wasn't even over the hose on 1 side.
I will post a pic after this weekend.
Just take 2 minutes to look at hose clamps and other visual hose situations
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
No leaks when you used the Boost Leak Tester though?
- Apr 14, 2003
- Hessel, Michigan
No, blow off valve is good, worked like it should
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Last year when we got our first sidewinders there was a lot of cases of loose and /or mislplaced clamps. The three sidewinders we have all where good but it is an easy check. Pop the hood off ,get a flat head out and check them..
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Good advice Terry. Once you've got everything torqued, mark the clamps with a paint pen and you can see at a glance if anything has moved:
- 13K
- 6K
- 15K
