Stoli
Here is a picture of how i have the TCV connected and this is how it was connected out of the box.
The hose i have going through the doghouse comes from the bottom of the intake and goes to the top of the TCV valve. The other hose is shown pretty well in the picture.
spell check didn't work on Photobucket... before i saved it... "controller"
Dimebag
Yeah, Thats how i have it connected.
We found a picture of a tcv connected in a totally different way,
Probably a older version or different type tcv.
Just wanted to be sure. We ride at about 2000-4000 feet, and seldom see any change in the boost level where we ride.
Thanks man
Thanks man
Dimebag said:Yeah, Thats how i have it connected.
Thanks man
2500 ft is roughly 1 psi loss in atmosphere, So it's possible it's just not enough to see.
Dimebag
Yeah thats what we figured.
Do you know how many turns is needed on the adjustment rod for every psi increase?
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
Dimebag
Looks great sonds,
Have you got a proper test ride on it yet? What elevation are you guys riding on?
Stoli
Dimebag said:Looks great sonds,
No rides yet.. Sonds and I live across the street from each other.
Hoping to ride this weekend in the UP... but that may not happen.
Ironwood MI is about 1200 feet
Hoping to ride with MTDream in a few weeks - but we may need some more snow... THis is about 6500 where we park up to 9+ thousand feet.
Dimebag
Ok, so you are basically in the same situation as me, that you probably wont see any change in the boost level where you usually ride.
But if you hook up with MTdream you should be able too see an increase in boost.
Let me know how it works out for you. We have been in contact with Erik at MCXpress (the "inventor") of these kits, and he told us something about a value with could change to make the TCV act more agressive to elevation changes.
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
You lose hp with elevation...boosted or not...you can however run more boost with the same octane at higher elevation
LSXM3
Stoli How many of you are going to the UP? im thinking of riding this weekend as well and I am still trying to figure out where to ride! What area are you going to ?
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
What value? And where do you change it?Dimebag said:Ok, so you are basically in the same situation as me, that you probably wont see any change in the boost level where you usually ride.
Dimebag
Tarzan,
Talk to Preben. He got the instructions and neccessary software from Erik last season. We have not tested it yet.
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
LSXM3 said:Stoli How many of you are going to the UP? im thinking of riding this weekend as well and I am still trying to figure out where to ride! What area are you going to ?
Stoli and I were planning on going, but I just found out I have an oil leak somewhere.
Looks like at first glance its coming from the stator cover?
I diddnt think there was much oil behind that cover?
MotoPsycho
Very little. Did you have that cover off? there are a couple of places that need a bit of RTV during reassembly if it has been removed at all.
LSXM3
sonds said:LSXM3 said:Stoli How many of you are going to the UP? im thinking of riding this weekend as well and I am still trying to figure out where to ride! What area are you going to ?
well let me know if you need a hand working on it, i met you the day with Scott when he was showing me the SDR under tunnel on his sled! It would be fun to get out and ride with a couple of you guys as well!
