Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
So, I'm thinking about changing my track to a 1.6 Ice Cobra. The last time I repacked the drive axle bearing I had to split my caliper to get at it. The back half of the caliper is seized on the axle at the bearing. Does anyone have a trick to get the bearing to move on the axle? I don't care about the bearing surviving the process, they're cheap. There just isn't a lot of room in there!
I could make a template of the mounting holes and maybe press the axle in a bit to start it... If I pull the bearing retainer out of the chaincase, maybe the axle would start to move?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Mine is always stuck too, I had to use a 3 arm bearing puller to get it of the last 2 times
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
That's a good idea, I never thought about that. I could get one at an automotive store I'd imagine...
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I have made a puller with the 3 bolts patterned on the caliper assembly out of half inch plate steel. Had the centre drilled and a nut welded in the middle that will accept my puller. I pull the caliper assembly off the shaft. Works great.
Failing that, use heat and keep working it. Careful prying against the tunnel, its pretty thin.
MS
MS
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
That's what I thought about doing.I have made a puller with the 3 bolts patterned on the caliper assembly out of half inch plate steel. Had the centre drilled and a nut welded in the middle that will accept my puller. I pull the caliper assembly off the shaft. Works great.
MS
I would think maybe an old school harmonic balancer puller might line up with the 3 bolts?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
My puller kit from Princess Auto with the 3 slots did not line up, so I had to go have it made. Initially I was optimistic but it wasn't meant to be.
MS
MS
RAMSOMAIR
Travis from BOP posted a puller here somewhere!
RAMSOMAIR
Fast
- Sep 25, 2018
Don't do it the 1.6" lugs bend too much robbing traction , look into the storm 150So, I'm thinking about changing my track to a 1.6 Ice Cobra. The last time I repacked the drive axle bearing I had to split my caliper to get at it. The back half of the caliper is seized on the axle at the bearing. Does anyone have a trick to get the bearing to move on the axle? I don't care about the bearing surviving the process, they're cheap. There just isn't a lot of room in there!
