APEXMAN
hi all yama dudes i just purchased a new 2011 xtx and wanna put 114 studs down the middle which pattern are people doing i was gonna buy a woodys template .. or should i just use a v patern any input would be good ,,, thxs steve
pro116
I usually make up my own template.I'm a firm believer in using double backers.There is more supports so the the backers don't cut into the track.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
pro116 said:I usually make up my own template.I'm a firm believer in using double backers.There is more supports so the the backers don't cut into the track.
X2, or go round backers! Ask me how I know
smitdog55
I'm planning on doing the same and was thinking 192 studs, why go with the round backers? I noticed in another post somewhere not to use round, i realize these are just opinions but would like to here what happened IRV?
Nick1945
smitdog55 said:I'm planning on doing the same and was thinking 192 studs, why go with the round backers? I noticed in another post somewhere not to use round, i realize these are just opinions but would like to here what happened IRV?
Don't forget, you have an odd number of lugs, 57, in the 144 track. If you went 4-2-4- all the way around, that would give you 190 studs, 3-3-3, will give you 171, 2-3-4, will also give you 171, and 2-2-4, will give you 152.
natedawgedog
I bought the woodys template and it worked out great for me (i didnt have to think about measurements) but i put 114 on mine and it worked out great, great hookup on hard pack!
- 149K
