jw440/800
I know not another stud question, but I was wondering which studs I want to use in my XTX with Hurricane Power Up Kit.
I am on the fence between Gold Digger Traction Master and Mega-bit stud, not sure which one I want, I think I'm going to either go with 144 or 171
Also stuck on fence whether to get 1.325" or 1.450"
What is everyone using?
If not Woody's, what have people found that work better?
So many options
So many options
nor'easter
- Feb 12, 2008
- Pennsylvania
- Nytro RTX SE
Studboy has a brand new backer which is completely new in design to the market. It's called a Super- Lite Pro Backer. It looks very interesting. See www.studboytraction.com
I would use at least 1.45 and I like mega bites. I have 152 and wish I had a few more. 57 pitch track so I have a 2-2-3 pattern right know but will be getting longer ones and adding some soon.
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
152 Fast-Trac studs Triple X Series 1.375 with polymer backers.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
I got 114 on mine and hooks up just great 1.450 git-er-done
jw440/800
I'm just worried that with the extra power from the Hurricane Hindle kit, that 114 wont be enough to get good traction
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Are you going to do alot of drag racing?
jw440/800
We live on a lake so I do go out and play but I try to do more ditch banging
shadow44
jw440/800 said:I'm just worried that with the extra power from the Hurricane Hindle kit, that 114 wont be enough to get good traction
114 wont be enough...I run that kit and have 144 mega bites....traction is an issue.
jw440/800
shaddow44 said:jw440/800 said:I'm just worried that with the extra power from the Hurricane Hindle kit, that 114 wont be enough to get good traction
Should I go 152 or 171, I just dont want to have a ton of studs and I want to keep them in the center?
shadow44
I would follow the " 1 stud per HP " rule...so 152 should be good.
jw440/800
I'm going to follow that rule and do the 152 1.45, now just have to figure out backers, may try the new stud boy superlite pro backer.
Pros vs Cons ?
Pros vs Cons ?
shadow44
If that's the plastic backer I wouldn't....my brother in law bought those the first year out...every single one of them broke...Studboy sent him all new aluminum ones.
jw440/800
Wow great to know looks like I'm going with aluminum square backer with tall nuts
Blu2U2
I am going with 171 in the center belt only. Here is what Woody's recommended if you want to avoid the direct center area....
"David, Mark here at woodys. David if that is the case then you would not do the three singles per pitch because some of them will be in the center. If you want to avoid the center of the center belt then I would use the 128-temp that template will do a single and a double in each pitch. It also avoids the center because the fire cat that it was designed for had a center tunnel protector if you do the 153 pattern using doubles and singles it will give you 171 because your track is longer.
Mark Musselman
Director of Development"
Mark Musselman
