06attaker
I thought I read somewhere that the supertech 6607 is a direct replacement for the yamaha filter. I just tried one and it doesn't fit in the opening. It is a little longer than the oem. Probably just should have went with that.....
RayKnobs
What's wrong with the k&N 147 w/nut?
06attaker
Was just at Walmart and picked one of these up. Thought it would fit.
09phazermichagan
hey does anyone make a filter relocation kit for ower sleds?
09phazermichagan
putting a six inch filter between the A arms whare the tool bag was would be sweet it would help cool the oil to!
soul_hammer
you dont want the oil to stay to cool it has to hit at least 150 to evaporate any water contamination and flow properly. but a relocation kit to make it easier to change the filter would be great.
I dont know if it would be.We only have to change them once a year and everytime I do it I always find something wore or needing updates when its all apart.Probably wouldnt catch things as well if filter change didnt require so much dissassembly.
xrrider
Spoke with Chris at Schmidt Bros about a month ago and said that he was finishing up on a filter relocation kit and will be available this season.
david galloway
try the late model mazda miata oil filter relocation kit. that should fit your phazer.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
I have the ST6607 on my 09' with no fitment issues, it was just a touch longer but it fits. I put mine in by the clutch a-arms, the plastic pulled back far enough to get the filter in through there and on the engine then I tightened it from above.
06attaker
I finally got it in. Just turned the skis to the right and put the oil filter in through the steering boot on the left side.
