Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
David Hasselloff he is not to good at mechanic....Wow...did Ray Charles install that?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Nobody messes with the Hoff!!David Hasselloff he is not to good at mechanic....
It's been done by me in past. Difference is I saw it and replaced battery. Hard to believe he didn't see it but it's possible.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
They said it was like that out from the box...lol. Yeah right!!!
Case closed, next case....
rlbock
So did your dealer replace the damaged battery?
gweever78
- Dec 14, 2017
- Michigan
- Yamaha Sidewinder
So is there a better and or lighter option to the winder battery? Can’t believe it’s only a year old and doesn’t hold a charge,,,,,,,,junk
5 years and 10000mi on my stocker and still going strong. Its luck. Sometimes you get one that lasts other times they go in less than a year. If I replace ever it will be another Yuasa just like it or Deka which is made in PA. Then cross my fingers. Sorry. Thats my experience with batteries.So is there a better and or lighter option to the winder battery? Can’t believe it’s only a year old and doesn’t hold a charge,,,,,,,,junk
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
What Cannon Dale says... And it's still under warranty... Or should be Goodwill by Yamaha... What I have found if a guy accidentally drains it down to a low enough point... And temps go below freezing... The fluid freezes? And the battery is junk....
So a good battery tender solves that... And I've even revived dead ones with a desulfater charger
