Swelling of the slide rubber membrane
RX Buck
Age
48
Grand Rapids MN
Website
mobilepredictive.com
2017 Yamaha Sidewinder LTX
LOCATION
MN
Has anyone had any trouble with the rubber membrane on the slides swelling to the point where they no longer fit under the cap properly. All 4 of mine did this and now I had to litterally stuff the rubber under to get the cap on. I have lost power also. I think the slides are no longer opening all the way because the membranes are kinked. I may have to get new slides for this thing unless anyone else has any ideas. Any help is appreciated.
Thanks,
Buck
carbs
i have seen this before only on one carb we put it out side at -20 to shrink it back down or they can be put in the freezer for 1/2 hour. when we went to get it replaced it had went back to normal on its owen :? this happens with some fuel aditives
its important that nothing but gasoline touches the rubber
dont try to clean them with anything as they will swell-esp things like brake cleaner etc-sometimes if too much drygas(alcohol)is added to the fuel in the tank this will happen-take them out and let them dry out overnite then get them really cold,put a little dab of grease around the carb top where they seat this will hold them in place alittle better
