Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Hmmmm....thought I checked all the bolts. Just noticed the ones at the bottom, from the original thread. I'll pull things back apart.
ZachXSmith86
- May 14, 2016
- Michigan, Otisville
- 17 Sidewinder ltx se
Is this happening on all sidewinders, jt I can't see anything abnormal about your photo, maybe I'm missing something. I guess I'm use to never having a problem with my yamaha sleds. This will turn me off quickly if yamaha puts out a pile of
that can't handle high mileage. I always prided myself on being the guy that doesn't break down..... sad days are coming if this stuff happens to me.
Doc Harley
- Oct 17, 2016
- Here & there
Two issues are the rubber boots to the throttle bodies are on the loose side. So give them a turn.
Second, check all bolts on turbine. Some have found them to be loose. Not limited to the six that you see on downpipe.
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Hey Dan, Great idea. Did you have to drill new holes in the rails to mount that kit ?
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
My XTX 141 has a factory anti-stab on the skid.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah, you open up the rail cap holes if I recall....been awhile since 2012 when I did those. Worked nicely though.Hey Dan, Great idea. Did you have to drill new holes in the rails to mount that kit ?
Dan
- 26K
