TD Powertrail CAI PSI?
Do you think if I traded my sandale 3, for a TD SQ, and ran 3 bar and TS bov, on either PT, or max 16, it would be a good running sled?I would love to see 17 psi when I need it,which would be running long fast trails,and lakes.
Told you before. MAX 16 is a stock muffler only tune. MAX 17 or PT is what you would want to run with a muffler.
Yes I do remember,funny though motorhead is running it on amodded muffler,and its fine,just don't want to go max 17 and have to search for 91 or 93 all the time.
Yep I am. What I had for a muffler mod was stock inlet, modded internal with a 3” outlet.
Got nervous about some claims of Wardens measuring sidewinders exhaust in area that we were going to finish off the season in, so I had the outlet changed to stock size, 2”, and then added the Max Spool 16.
That is why I say partial smm. Much more power then my previous ecotrail tune. Have only put 2 days of riding on this set up, about 400 miles of county perfect trails. Hardly a bump to be found, so plenty of turn on time.
I am pretty sure that my 87 octane days are over, with this tune though. I was getting 15.9 boost, but was told by another that this map is a 16.8 map. Will put BOV on it next year. Cheap enough and shall test/ ride it more next season.
