sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
ok newbie here. I have a 2006 vector and we had maybe a half inch snow. took it around yard for maybe ten ,fifteen minutes overheat light came on. 19 degrees out. coolant level fine. should I be concern or not. lack of snow problem?
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Not enough snow IMO but make sure your sled's cooling system is fully purged of air. Besides lifting the front and rear to get the air out, I would run the sled for 15-20 minutes with the radiator cap loose then tighten it.
Do the 06's have the rear tunnel cooler? If not I personally would add one ASAP. Inexpensive improvement and easy to do. Hibshman (Barn of Parts) should have one.
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
I dont believe they have rear exchanger and I am feeling better now lol. I agree all normal whew
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Temp light also comes on prematurely. Add one of our engine savers and it will alert you by activating reverse beeper when coolant reaches 240 degrees. There's info on my website.
I have an 05 Vector and this happened to me when it was knew. Found out Yamaha runs straight antifreeze in them. I took some coolant out of the tank and put 50/50 antifreeze in and never have had my temp light come on again in low snow conditions. Over 13,000 miles on sled now.
sfcjeff
- Nov 7, 2014
- central wisconsin
- 2006 rs vector gt
thank you
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I'm guessing that you were just puttering around the yard slowly, stopping frequently and combining that with low snow likely caused the overheat light to come on.
Tips:
- go faster in order to throw snow at the front heat exchanger
- add a rear tunnel heat exchanger
- thin the coolant strength with distilled water...Yamaha sends them out with -60 degree strength coolant.
Since the Vector also has heat exchangers mounted outside the tunnel under the foot boards, if you still encounter an overheat situation, pile snow on the foot boards while riding. It helps under extreme conditions.
Tips:
