The Single Shot Solution Rev2!
Hygear Suspension has developed a coil over solution for the Yamaha Apex and Vector chassis using the single shot rear suspension.
The undersized stock 1.5 float shock is replaced with a much larger 2.0 Fox Coil-Over platform that is built using Hygear Suspension’s custom Fox H1 build specifications. This shock features a large capacity damping control that is more suitable for a single rear shock application. This shock also offers spring preload and low speed compression adjustment that provides reliable service for trail conditions. The shock kit comes with additional accessories needed for mounting that also helps improve suspension movement. Testing has proven there is major difference in ride performance that feels much more comparable to the original Yamaha Mono shock applications. The suspension now utilizes full travel to help smooth out the small to medium size high speed repetitive stutter bumps with improved bottoming resistance for larger moguls. The Rev2 kit features updated internal components, revised calibration and mounting hardware.
Visit the link below for more information:
https://www.hygearsuspension.com/products/fox-hygear-h1-apex-single-shot-2-0-ra-coil-over-rear-kit
Part #50-03-030-A, $819.99
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Thank you Hygear! Sounds like you did your R&D unlike Yamaha! I just wish Yamaha would stand behind their product. When I get close to paying off these sleds and their worthless YES warranty. I will definitely buy your product. You as far as I am concerned as good as Fast! No insult intended. Just wonder why they did not approach this issue. The best rear suspension I have ever bought.Was a Fast M10 with Titanium arms I bought from Dave Karpic on EBay. I picked this up at the Sawmill bar in Virginia Mn from him personally. He told me I got a great deal 136. I bought it for my 2001 modified Cat. He was right! took me many years to install this. I got jealous after I bought my Wife with MS a new 2016 Vector with PS. So now I am stuck with 2 Vectors with defective rear shocks that they won't fix! My wife even commented on my last ride last year because I rode my Cat and let my youngest son ride my Vector. She said you sure were enjoying yourself. I was in the
Lead. I told her it was because of the better suspension. And lighter weight. By the way my son found a spot to play on the Vector and he was all smiles!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Good to see companies making shocks for the singleshot suspension.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
What's the difference with the fwd coupler blocks in the kit?
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Love these guys...only a few hours away, so I dropped off a pair of old monoshock's from my 06 apex and a newer vector, to get the dual rate setup..nice clean shop, and super helpful. The dual rate setup is top quality and works great! Minimized g out bottoming, yet still gives a plush ride! If they say it, it will do it, imo! And they give choices...my oem shock shaft was pitted, so they can make a new one, refinish the old, or get another shock. Nice to have choices and prices.The Single Shot Solution Rev2!
Apex2007
- Feb 20, 2015
- Saskatchewan
- 2016 Apex xtx 1.75
2007 Apex ER
Has anyone installed one of these shocks on there there single shot just wonder how it working thanks
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
wow only 819.99 lol
1320
I installed a elka stage 4 in my 16 apex which i bought new ,rode 1 season with silly stock shock and didnt want to deal with updated shock (hygear had not come out with a shock yet) . Its not a bad shock but i dont think they tested it much ,Hygear much better but Ill stick with it for another season. Whats really a bummer is Yamaha continued to make this great sled with this garbage suspension for 2 more years ,knowing it was crap . I love my apex but next sled will not be a Yamaha.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Been since 2019 on my hygear coil over they setup for me. Awesome shock. I am 250lbs naked. Have about another 80lbs on the sled between 3k lb warn portable winch I made, sno jack, saddle bags loaded with stuff,tank bag,windshield bag.
provfisherman
- Nov 1, 2015
- Manitoba
- 2016 Vector XTX
2015 Venture MP
I have the Elka shock on my 2016 Vector single shock. I looked at the Hygear, but when accessing the installation procedure, I saw that the Hygear required modifying the OEM system by drilling out certain suspension items and the Elka shock did not require any mods except for using a longer bolt (which was supplied). Since both companies had a really good reputation, the lack of modifications swayed my decision. I have had the Elka for 5 years now and I do not regret it. the Vector rides soooo much better then that horrible air shock that came with the unit.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Glad to hear it's working for you. Nice not to have to worry about air pressure or leaking. The Hygear has a heavier duty shock and hardware.
RobX-1
- Coldwater, OH
I will prefix this by stating that I realize I may be an anomaly but with regular maintenance, I was able to rack up over 13,000mi on my Fox Float EVOL before having to replace it. Funny thing was, it wasn't an air pressure or leaking issue that took it out. Happened right before this year's TY ride so in a mad dash to get it ready, just opted to replace with what I had considering the success I have had with it; that and the awesome price Port Yamaha was/is offering.
