09nytro
![Jump :jump: :jump:](/styles/default/xenforo/smilies/jump.gif)
fxnytroxtx
Guest
nigga please09nytro said:over some stupid torx screws : you wish you wouldn't have sold your nytro
now that's funny
Stiff?? have you adjusted your skid and shock pressures?
fxnytroxtx
Guest
When yamaha made a mistake you where crying al over the net like a little biyatch, when cat makes a mistake its all good right?
09nytro
fxnytroxtx said:nigga please09nytro said:over some stupid torx screws : you wish you wouldn't have sold your nytro
now that's funny
What ?
I just thought it was the funniest thing
fxnytroxtx
Guest
everything is on softest setting, I could be spoiled by the axis I had on my nytros thoYamadog said:Stiff?? have you adjusted your skid and shock pressures?
fxnytroxtx
Guest
I like the sled for the most part, I'll get custom axis for too if I want to. Things that might have been a problem for you with nytro where not problems for others, not saying it didn't have them, but let's face it no dip sticks no drain fill holes, steaming like a locomotive train, striped srews and bolts oil problems?09nytro said:fxnytroxtx said:nigga please09nytro said:over some stupid torx screws : you wish you wouldn't have sold your nytro
now that's funny
What ?
fxnytroxtx said:everything is on softest setting, I could be spoiled by the axis I had on my nytros thoYamadog said:Stiff?? have you adjusted your skid and shock pressures?
Well then put one on this thingy cause I have ridden several stock nytros shorty and xtx and there is no comparrison the Viper is hands down a better handling and feeling sled in the stock form. When I first rode mine it was stiff then found 150 lbs in the rear shock backed her down and rides like a caddy
fxnytroxtx
Guest
define handling? Yes like the viper better in terms of taking high speed turns with one handYamadog said:fxnytroxtx said:everything is on softest setting, I could be spoiled by the axis I had on my nytros thoYamadog said:Stiff?? have you adjusted your skid and shock pressures?
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
Suckur
My 450 lb 165hp 800 twin will kick all y'all's asses! I'll see your steam and raise you some two smoke... ![Wut60 ;):D ;):D](/styles/default/xenforo/smilies/wut60.gif)
Re: fit and finish
x2. Side panels are a breeze. Not the best fitting out there but takes 2 seconds to pull and put back on. I will take removing these panels over the lower apex/vector panels any day of the week.
Suckur said:The side panels are very easy to install. The torx fasteners do not rust. I've ridden this chassis for over a year and have never experienced what you are describing here.bigdog_mike said:It will be a nightmare to install the side panel out on the trail in cold temp...think it should have used yamaha side panel fasteners instead of lock and swing together then wrestle with plastic panels, all the torx screw plating will rust before your eyes...could they atleast made the fasteners with metric machine threads and hex bolts for crying out loud...tore off the hood to access light pod...good luck getting it to fit back together...way too many torx screws into plastic...come-on at least add clips so you can reassemble...
Suckur said:My 450 lb 165hp 800 twin will kick all y'all's asses! I'll see your steam and raise you some two smoke...![]()
Bring it on
![Smiley Faces7 :-o :-o](/styles/default/xenforo/smilies/smiley-faces7.gif)
fxnytroxtx
Guest
those look sweet. But we had bad luck with fox air shocks in the past leaking air freezing up, on 2013 800 rr and on 09 nytro se in one season. I rode both and I prefer penske coil overs, yes they weight a little more but that hasn't been an issue for me (weight) I hear good things about ohlins ttx and I have yet to try themYamadog said:Are you talking the Penske shocks?? if so just go with evol rc2's they are even more adjustable. I did not even ride mine with the stnd fox float 3's
fxnytroxtx
Guest
Oh and there's just one more thing that I don't like is that huge awkwardly positioned throttle lever, my thumb still hurts ![Hide :hide: :hide:](/styles/default/xenforo/smilies/hide.gif)
