WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
What did you do on the belly pan? I cut the rubber back but the tip is really close to the plastic. Did you remove the metal ring and cut the hole bigger?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
i have a td 3” race pipe and only cut the rubber out to fit and its good .6000 km and no problem no need to cut metal ring.What did you do on the belly pan? I cut the rubber back but the tip is really close to the plastic. Did you remove the metal ring and cut the hole bigger?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
That's what I figured but wasn't sure if it would get hot enough to melt the plastic.i have a td 3” race pipe and only cut the rubber out to fit and its good .6000 km and no problem no need to cut metal ring.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
mine didn’t melt at 20 lbs of boost lolThat's what I figured but wasn't sure if it would get hot enough to melt the plastic.
yamaha06
I'm running the hindle pipe on mine and it had melted the plastic.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
I had to cut into the plastic/metal on my '17 to get it through, on my '18 I only had to trim the rubber. No issues in 2800 miles on the '17 with the SanDale 3".
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
Both 3" Sandale exhausts fit inside the aluminum ring on mine, just had to cut the rubber a bit. Anything larger than 3" will need to lose the ring.
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
After seeing how easy it went in my '18 vs my '17 I'm convinced it's just assembly variation from AC - holes in the belly pan or the ring itself being a 1/8" different from one sled to another.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No problem on my 17 SW I have sandale 3" f/s if anyone wants it,pm me.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
PM sent Pete !!
- 29K
