attakred06
any of you guys have tried snowtrackers on yam ski? well after you will never want nothing else,,anyway it is never hard to steer when the ski dont touch the ground!!!!lolwith 21000 klm i used 2 set since 2006 on my attak.
sled frog
- Dec 18, 2010
best combo pilot 5.7 with 4 inch woodys outside and snowtrackers in middle
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
Pilot 6.9's on my Apex and no regrets. But defintely true that the plastic is softer and scrapes and gouges up easier.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Well, logged a few miles with the pilots and they are much improved over the stock Yamaha skis. A couple buddies ride Apex' with stock skis and they dart like crazy. Only issue I found is a bit of push in the corners but a small price to pay to get ride of the darting.
Ski-Dog
I have had pilots on my Attak for the last 3 years. I find they do push a bit in softer conditions like some said and overall over the stock skis my personal take is that the improvement was marginal. Just my personal experience, does improve darting if that is a concern.
I love mine and so does my wife.
wkeggenhoff
- Dec 20, 2007
- Ajax,Onatrio, Canada
- 2006 Yamaha Apex RTX
Pilot skis apex
Best mod I have done so far.
Tried everything with stock ski's. Duallies ,single 10" host bar, Transfer full, half , no transfer, Strap up,down sideways. May try snowtracker in middle when these carbides wear out. Sled basically rails now. I do have wide front end kit on as well
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
apex55 said:pilot skis are great on the apex. Add 6" shaper bars on the middle and 4" on the side. Great combination. If you don't put any on the side your skis will wear out.
^this .....also setup your front A arms parallel to ground(level) ,along with a 13mm sway bar ive run since '06 and still handles like on rails.
Dan
ShootToThrill
jaydaniels said:Well, logged a few miles with the pilots and they are much improved over the stock Yamaha skis. A couple buddies ride Apex' with stock skis and they dart like crazy. Only issue I found is a bit of push in the corners but a small price to pay to get ride of the darting.
Shaper bars will help with some of the push. Start with one set of the shapers in the center of the ski.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
The darting doesnt bother me as much as the push.I only have one ride on the skis and it was loose snow, but it pushed like crazy. I was hoping on better trails they would turn better than the stock skis
apex55
ROCKERDAN said:apex55 said:pilot skis are great on the apex. Add 6" shaper bars on the middle and 4" on the side. Great combination. If you don't put any on the side your skis will wear out.
Dan
What Dan says here makes a huge difference. I did this last year and am quite pleased
race24x
- Dec 29, 2003
- Belgrade, Maine
Is it the shaper bars or the sway bar that makes it turn better
CaptCaper
- Jan 1, 2007
- Northern N.H.
I just ordered a set. I've read posts now for years saying they like them. I really haven't heard much at all negative about them so I needed ski's and they were resonable.
I hope I'm happy with them on my Attak with studs.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I put a pair of 5.7's on my vector and they push like bus in the corners. Tried sucking up limiter strap 1 hole, changing the control rods to #3 setting, dropped front shocks almost all the way down, backed off center rear shock and added a 13mm swaybar but still haven't been able to test with this setup as I'm waiting on parts. Thinking about trying the new mtn skis from Yamaha if this setup doesn't work. The 5.7's are no better than stockers in snow. I probably should have tried 6.9's.
apex55
The sway bar will help with ski lift, with out it each side is completely independant. Alot of mountain sleds don't have them for this reason. The shaper bars, because of the concave on the sides, grabs the snow and helps eliminate the push.race24x said:Is it the shaper bars or the sway bar that makes it turn better
