SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
211 hp for 0 mile Thundercat! Let the games begin!
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Leaner A/F for whatever reason. 11.5 vs 12.5 on the Cat. This contributed to more hp along with some ethanol content in the Cat.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
This is very nice
Production sled?????
Can you post the data to support that?
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Oh, please don't tell me that I should've bought the cat version. Darn it! Yamaha clutching and ecu tipped the scales for me. Hopefully production models will be similar. Otherwise I will never hear the end of it from my cat buddies.
Well I would stick with a 204 hp verse a 210 hp if there was a risk with those AFRs being too lean with the wrong fuel.
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Wow 210 on a new motor is awesome. Sure glad I spring ordered cuz this new Yamaha motor is going to be a beast. It was 90 degrees here this weekend but me and my buddies were talking sleds. 2 of us are getting new Winders and another is boosting his Doo 1200. Think Snow!!!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
percentage of ethanol??
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
same motor...same ecu...same exhaust......maybe the 204 with the leaner afr was the pre production and the new is the production model...
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
The cat was leaner with a 12.5 afr
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
The more I think about it, 7 hp difference seems to be pretty large. I can see a couple hp variance, but more than 5 is quite a bit. Especially if we're talking same exact engine and amount of boost. You usually have to do an actual mod to get an increase of 5 hp on most sleds (exhaust, etc.) Correct me if I'm wrong.
SideHogger
- Apr 16, 2016
- upstate ny
Guys, if you want all the facts, please support DynoTech and sign up for a subscription. Jim is a great guy and deserves our support for all the info he has given out all these years. He claims early production sled with 0 miles! If that's the case, imagine what that sled will make broken in!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Just a degree or two of timing and tweaking the afr can make a big difference. A more aggressive tune (timing,afr) could do it. But now
you are closer to the edge if you get some crap fuel.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Doesn't it correct for bad fuel ?Just a degree or two of timing and tweaking the afr can make a big difference. A more aggressive tune (timing,afr) could do it. But now
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Sensors cannot adjust for pre-ignition. Lots of good reading. Well worth the annual subscription.
- 11K
