dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
My steering tirerods need some adjusting. My left ski tie rod is showing about 4 threads and the right ski is showing about 10 threads. They are showing equal threads under the hood when compared to the outside. Will this be a problem? If so how do i fix it?
09nytro
Is anything bent...a-arms , subframe ect.
natedogg3
are the skis in alignment?? dont worry about it!
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
skis are alinged, they are toed out 1/4inch. Subframe and a-arms are straight. I suppose i could adjust the steering post tie rod which will then allow me to adjust the ski tie rods.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
dremmick said:skis are alinged, they are toed out 1/4inch. Subframe and a-arms are straight. I suppose i could adjust the steering post tie rod which will then allow me to adjust the ski tie rods.
Yeah you would have to adjust the steering post some then you could get your tie rods with equal threads showing. Its almost impossible to get at the rods in the center when its all together though.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
True that, it's a pain in the butt. I will have to adjust them sometime when I have my sled apart. For now I will just cross my fingers
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
dremmick said:True that, it's a pain in the butt. I will have to adjust them sometime when I have my sled apart. For now I will just cross my fingers
Did you have it apart? How did it get off center like that.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I just bought it last yr and just now noticed it.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Oh got ya, I see 09 front end in your signature. Thats probably when it happened, they didn't center everything up while putting it back together. Not a big deal as long as its aligned correct now
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
dremmick said:OFT Relocator
Just reading through your signature, but did it always have the OFT Relocator?
If it did, then the person who put it on originally used the heim joints out at the spindles to put the handlebards back straight again. When you install an OFT Relocator you need to loosen the heim joints on the steering rod from the post to the "bell crank" because changing the angle of the steering post turns the handlebars to the left.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I added the oft relocater. Good to know thanks!!
