How do you get at the hidden tie rod "nut"
From the side or remove bottom plate?
Any tips on removing it
09nytro
Take the boot off , turn the steering to get the nut out so you can get a wrench on it
Thanks..any trick to getting the plugs out
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Need to pull out the center pin. Use a screw driver to pry it up so you can get ahold of it. Once you see how they work, you'll get it. Buddy has a very small cats paw nail puller with the claw ground open and it works great for those pesky pins.Thanks..any trick to getting the plugs out
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
They make a trim pin tool that you can get from Matco, Snap-On, etc or gently with a set of side cutters
ah ha...They make a trim pin tool that you can get from Matco, Snap-On, etc or gently with a set of side cutters
