BordnBill
Just wanted to let you guys know that if you get one of these bumpers and you have the Roest Skid Plate, you may have to make some mods to it in order to get the Boonie Bumper to align with the lower mounting holes. Just spent 3 hours installing mine. The Boonie seems to be designed with very tight tolerances to the factory plastics. The front of the Roest plate tucks up in the front nose cone just a little, but this little bit causes issues with the rivets in the mini plate that comes on the Boonie. I had to notch out some spots on the Roest Plate to clear the rivets, and had to taper the front of the Roest plate so the Boonie would line up with the bottom mount. Not sure if this was in issue before with these bumpers? And I also had to trim some of the nose plastic where it overlaps with the Roest plate. Now that it's all installed, it looks good. But it definitely was a pain in the arse.
