TIMING CONTROLLER SET UP.
looks like the TIC-1000 may not work on the three cylinder, I don,t know that the msd set up will work with the MCX kit due to the return oil pump location, any ideas.
Did you ever end up adding/removing timing on your MCX 270 Nytro. I have a PCV with timing module and would like to add timing in from clutch engagement to pre boost for throttle response. Looking for input on how much timing I can add using MCX supplied head shim. Based on some research I am seeing some are reporting 3-4 degrees would be acceptable..
