phazerman2000
My 07 fx was pretty tippy in the corners so i did a little research on the sway bar. It comes stock with a 13mm bar. The MTX comes with a 14mm bar. Just order the sway bar and mounting bushings for the MTX, swap it out on your FX/RTX and you will love the results! Worked wonders for the cornering on my 07 FX! Price was right around the $160.00 mark for all three pieces.
DaveRX1
My FX is not tippy, I pulled up the limiter strap one hole and reduced the ski shock preload and center shock preload to min. Increased ski shock comp damp two clicks
