putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Looking for some tips on splitting the oil tank. I don't want to force something and end up doing something wrong to the tank. Whatever sealant is used on them seems to be really strong. I'd like to install the BOP oil tank gasket, but need some advice on how to split the tank. Thanks fellas!
Put some heat to it just didn't go crazy there's a plastic baffle inside. They come apart pretty easy just pry with 2 wide prying tools simultaneously and take your time working your way around. If your leaking oil start in that spot. You may be able to see the softer excess RTV sealant that has expanded out of the edges. Mine had very little sealant in there and I didn't think it was nearly enough.
When you put it back together run a bead on both pieces, put them together but do not tighten the bolts for an hour or so. Let the sealant firm up some first
bluewho
- Sep 12, 2020
- orillia
- 2021 winder
Hot Knifes
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Mine came apart pretty easy..
Like fatchance said use two wide prying tools and work your way around and it will break free..
Let us know how you like the BOP gasket..
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
Travis at BOP mentioned to only use the gasket after the surface is cleaned,no additional sealant,and half of the factory recommended torque(72”lbs) with blue loctite on attaching hardware.He mentions too much torque can damage the gasket
putz21
- Apr 15, 2013
- Tomahawk, WI
Thanks guys! Is the existing sealant pretty easy to remove/clean?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Like taking a bath!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Using a little gas, that material from the factory almost dissolves. Like the previous comment, knives or puddy knife (for drywall) would work - sliding it in, and breaking the seal.
Once separated, wash it good with gas or brake cleaner.
Mine came apart so easy, there was such little material holding it together. And that would explain why it was leaking. Lol
MS
MS
