Gman25
- Dec 11, 2019
- ottawa
- 2018 sidewinder ltx
1999 srx 70
1993 vmax 750
All shims sent out and to those who did not receive theirs i have sent replacements
sideshowBob
Got mine a while back...thanks again!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Please explain this chaincase shim?
There is room for a half mm shim to be added behind the top gear, yet still have the clips on. This keeps the top gear further engaged into the outer gear so it is less likely to disengage.Please explain this chaincase shim?
I put both of the stock shims on first, then the .50mm on the outer side.
DMCTurbo
- Nov 12, 2005
I'll have to double check mine when I open it up. I don't seem to remember 2 shims behind my top gear.There is room for a half mm shim to be added behind the top gear, yet still have the clips on. This keeps the top gear further engaged into the outer gear so it is less likely to disengage.
In stock form, there is a 1mm shim on each side between circlip and gear.I'll have to double check mine when I open it up. I don't seem to remember 2 shims behind my top gear.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I believe the play that is in it is perfectly fine. 10k and I see no reason for shims other then the way it was engineered. Sorry guys I strongly disagree with changing the free play. Let it go where it wants to be it will be just fine. It has a little back and forth play for a reason IMO.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I’m with jonlafon1. No issues on any of our winders with this. Just drive it and enjoy.
Gman25
- Dec 11, 2019
- ottawa
1999 srx 70
1993 vmax 750
We all know cats lack of engineering especially in the chaincase. For a 200 hp sled this chaincase is garbage hence why i and many others have had to re engineer things.
As mentioned the shim keeps gears engaged tighter. Prior to shim install i had a gear disengage at 40-50 mph horrible noise and hrll of a mess. Then all you have is reverse. Anyways 2000 miles since shim install and no issues best andmost inexpensive thing ive done so far!
NYTurbo
On the outer side ?There is room for a half mm shim to be added behind the top gear, yet still have the clips on. This keeps the top gear further engaged into the outer gear so it is less likely to disengage.
It was after the sight glass falling in on my 18 that I decided to arrange the shims this way. The one side of the fork puck melted off, but it isn't very thick. I thought to myself why would the gears not stay engaged even with that gone? So I assembled everything without the cover and noticed that the gear had more room to come to the right(when sitting on machine).
And I agree with Gman there is quality design lacking in the chain case. We all know that.
Yes, thin shim on outside.On the outer side ?
RAMSOMAIR
74nitro. You are incorrect! Gman is suggesting the extra shim he uses goes on the inside to push the gear outward.Yes, thin shim on outside.
slimjim2525
Gman, have you taken the chaincase apart after the 2k miles and see what the upper gear looks like? I now have 3800 miles on my replacement upper gear bushing. I checked it at 1800 miles and it was perfect. I will now check it again.
So am I more-or-less, except I'm using the two stock shims on the inside with a thin shim on outside. Read my comments again.74nitro. You are incorrect! Gman is suggesting the extra shim he uses goes on the inside to push the gear outward.
