NY_SXR700
- Dec 30, 2003
- Webster, NY
- www.sohonetworksny.com
- 2001 SXR700
2006 Apex-GT
Does that 36mm nut remove the "normal" way? left to loosen right to tighten. I can't remember but I thought my SXR was reverse threaded. Doug
4Fighter
If it's like the RX-1, it is right-handed.
TurboJamie
Nope normal threads.
NY_SXR700
- Dec 30, 2003
- Webster, NY
- 2001 SXR700
2006 Apex-GT
Thanks, where can a get a real tool to get that nut off. I have a 12" cresent wrench but that only opens to 35mm. I have been to two auto parts places and a 36mm socket at best is only 3" deep. I have a TON of tools but nothing that will get into this spot with this 36mm size. Will Harbour Freight have what I need? Doug
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Micro Belmont:
616-534-9681 or 616-532-2337
SRXracer
A big channel locks works great.
NY_SXR700
- Dec 30, 2003
- Webster, NY
- 2001 SXR700
2006 Apex-GT
Micro would be fine if my parts wern't on the floor with 20" expected in the next 24 hours. I could put it back together in a pinch. I also have the SXR as a backup. I will check a few other places locally tonight. Buster696 might have that tool as well. Thanks for the help. Doug
TurboJamie
Go to the flea market and get a socket for like 5 bucks then cut it in 1/2 and weld a piece of tubing between the 2 halfs thats how I did it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I got a Harbor Freight Tools in my area at home...bought a huge adjustable cresent wrench for $9.99....gotta love that store!
and YES the threads are normal,You might need a buddy to HOLD the secondary in place when you loosen nut...I tried a wrench on secondary bolt but it just loosened secondary bolt then...LOL.
good luck!
Dan
good luck!
Dan
Yamaholic22
holding the brake works good too
edit: Im retarded and was thinking of the two-strokes.
bdm
Yamaholic22 said:holding the brake works good too
no, I am pretty sure that the brake assembly has to remain removed to access the nut.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
LOL I wish it was that easy...unfortunately when you are changing your top gear the first thing you remove is your BRAKE!..
So obviously holding brake wont work.
Dan
Yamaholic22
lol, you're right. I haven't had one of the four stroke chaincase's apart yet, i was thinking of ALL the other yammy's that i've had apart hundreds of times. Gotta make the conversion in my head, im new to the four stroke camp. Really is a whole new ball game on a lot of fronts.
Shootinstick
I think I remember seeing a special set of tools on here for holding the jackshaft and torqueing the nut that sold for around $36. If anyone has the part number and source for those tools I would appreciate it.
Jim
Jim
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Shootinstick said:I think I remember seeing a special set of tools on here for holding the jackshaft and torqueing the nut that sold for around $36. If anyone has the part number and source for those tools I would appreciate it.
Jim
you will have alot easier time finding a big ole crecent wrench...probably find one online for very cheap...try a search on "pittburgh" tools...10 bucks at any harbor freight
dan
