YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
I'm taking my jackshaft off right now and really struggling taking that nut off on top, you are saying that it is left hand to loosen and right hand to tighten? Cuz I've got a big wrench on there and another big wrench for leverage and I can't get that thing offNope normal threads.
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
I have an 03 Yamaha rx1I'm taking my jackshaft off right now and really struggling taking that nut off on top, you are saying that it is left hand to loosen and right hand to tighten? Cuz I've got a big wrench on there and another big wrench for leverage and I can't get that thing off
Righty tighty, lefty loosey
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Just had mine apart for track change, 2003 rx1/ltx (now) its definetly standard Lh thread to loosen, I bought a socket cut it in half& made a socket that way you can torque the nut back on, also you can put a big adjustable on the hex of the track driveshaft to help keep everything from turning,I'm taking my jackshaft off right now and really struggling taking that nut off on top, you are saying that it is left hand to loosen and right hand to tighten? Cuz I've got a big wrench on there and another big wrench for leverage and I can't get that thing off
YammieMan
- Feb 26, 2019
- Winkler
- 2003 Yamaha RX1
That's what I've been doing, I have 2 wrenches each are like 2 feet long, I use one for leverage and I did put a crescent wrench on the axle to help stuff from moving, still no go. I will try the socket, only option I have now..Righty tighty, lefty loosey![]()
Brotherdan
- Sep 8, 2017
- Belmont,maine
Wow that’s not good, threads appear good& not previously stripped? Maybe someone didn’t have a socket to torque it& used lock tite? Shouldn’t be that tight I beleive torque is only 65 ft lbs, maybe try some heat to help expand nut& break loctite if it was usedThat's what I've been doing, I have 2 wrenches each are like 2 feet long, I use one for leverage and I did put a crescent wrench on the axle to help stuff from moving, still no go. I will try the socket, only option I have now..
I use a socket with my large breaker bar to take of that nut. I also have the socket for the other end of the shaft to help hold it. It better than trying to use the driveline to hold everything still.That's what I've been doing, I have 2 wrenches each are like 2 feet long, I use one for leverage and I did put a crescent wrench on the axle to help stuff from moving, still no go. I will try the socket, only option I have now..
