SledFreak
- Feb 7, 2005
- Ontario. Canada
What size is the top gear on an Attack. I know it's a 23 top gear, but is it a 13 wide gear and pitch? I have a 23 top gear from my REV, but I'm not sure if it will fit or will I have to order one.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It won't fit. Only a Yammie gear will fit on the top due to the shaft/spline diameter. You can buy them from Micro-Belmont, etc.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Got a Number....
grader
micro belmont--- ph. 616-534-9681 or 616-532-2337 or fax 616-532-2275
SledFreak
- Feb 7, 2005
- Ontario. Canada
Thanks....
sneakattak88
wich gear would you replace it with ,, a 24?
