Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Dano said:We done all this testing years ago. The old speedos were purposely reading high. The faster you go, the more off it was. Grinding one tooth off speedo gear brought it closer to reality at slower speeds and grinding 2 teeth made it closer at top speed. The odometers were always close to reality, about 2% from my experience. Grinding teeth off gear unit threw the odometer off. Yamaha got called out on it and gradually fixed it closer to reality.
Dan
Thanks for confirming this Dan. My testing produced the same results with a non linear speedometer error (+5% at 50 MPH and +15% at 100 MPH) with the odometer being within a couple % of accurate. Because the speedometer error is non linear and the odometer is accurate I agree that this had to be a deliberate manipulation of the speedometer display programming by Yamaha.
I am sure that there is a way to fix the non linear speedometer error electronically but it would involve a factory only interface and proprietary software. Each speedometer pick up gear tooth removed reduces the signal pulses by 6.7% so yes it would require one tooth removed for "trail speed" correction and two teeth removed for "lake running" correction. However because I like my odometer accurate I am going to leave my speedometer pick up gear alone and enjoy my optimistic speed readings!
