Torco octane booster
sheetwright said:
How high of boost have people tried/trusted these additives on flatland? I see Torco the more you add the higher the grade goes, but what is your personal ceiling you were willing to go up to?
I don't run low elevation but have been down to 3300 ft at 19# grass dragging.
Ken....
Does anyone know who sells Torco in Ontario. I bought some Amsoil 2000 octane booster
Lets say 6psi pump gas limit. Can you run 8psi with torco in the mix and be safe ? anyone done this?
I love water, way cheaper and easily accessable :-)
Yeah Torco is the one that works as advertised.
Yes, I run 8 lbs with 93 pump and Lucas octane booster at sea level.. Been running this for the past two seasons with no issues, knock on wood...:).
I've ran as high as 10 at 2k feet on 104 mix of torco and 90. Typically I run around a 100 mix for 8-9 lbs. Fairly cheap if you buy 5 gallons. $1.50 a gallon extra to get 100 from 90.
I run a 2l of avgas per gas tank when I want to make big boost. Its .30cents more per L than supreme. It works great but u can't keep it on your sled for later on that day.
I have used torco accellerator and it works great, I recently sold my supercharged mustang and have (2) 5 gallon cans left that i don't need anymore,
I will sell each 5 gallon can for $175.00 us... thats only $8.75 per quart.
Jeff Simon / SIMONS CPR 1-414-698-6611
Simons Only if I would have known a few days ago! I just bought some off a dealer. Guys this is a great deal!
A friend used some octane booster, not torco, but one of the competitors and in one or two tanks, his o2 sensor failed and it had black goop all over it. I use water meth and run 15 psi on the trail, I try to buy the best fuel available, I have run it two seasons, all pump gas.
If you intend to run stock compression at 15 lbs, I would recommend meth or higher octane fuel.
