Track seems uneven, more track on left bogey
shadbehnke
Age
36
Wisconsin
2009 Phazer RTX 136''
As title states there's and inch or so of track over one bogey but the other bogey there's no extra.
Checked tensioner and there turned out the same, any ideas?
Sent from my SM-G930R6 using Tapatalk
Rear wheel bearing is bad, could be bend front arm.. drivers could be misaligned.. take 1/2 turn out of one side and add 1/2 turn on the other and see if it walks over.
Yeah it does walk over but the tensioners are nothing alike comparing threads.
It does have a tracks-usa 136 ext and freeride track as well
No ideas anyone? Wheel bearings are good, no play on ubnt drive but when using adjusters I can get the track straight but the tensioners are off and track is quite a bit tighter on one side...
How much difference does it have to have to make it run straight?
A few full clockwise turns on the tension bolt
A few turns is not excessive. I would not expect them to be real close hense the reason for seperate adjusters. Are all the wheels the same diameter on both sides?
Sent from my SM-G920V using Tapatalk
One other thing is there mutipal mounting holes on the track extension and one side is offset. I would think you wouldnot be able to do it however just throwing it out there.
Thanks, going to look into it tomorrow some more
Could the rear axle be assembled incorrectly? Are you running factory drivers or aftermarket? Mis-positioned drivers can make the track impossible to align.
Just trying to throw out a few more scenarios. ;)!
