Track tension adjust question?
No clue, do you know how I could tell? Measure them? I also noticed I'm missing a wheel, the one that mounts near the bottom spring mount on the left side.
They are smaller in diameter. Not sure if they have snap rings though. They spin a lot faster (smaller diameter) and usually wear out faster.
The rear looks bent to me too, the upper wheels should be parallel to each other and they aren't in your pic.
take the clips out and use a socket to remove the bearings and you should be able to read the bearing number off the bearing seal...
Yeah checked them today and saw 6004 stamped on the wheel and on the bearing. Time to order em up
