yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
just wondering after all the tri hub worry this summer what the failure rate is?
I have 800 miles of no issues so far.
I have no failure on either on my Vipers yet... but I changed it on the XTX since I had the skid out. LTX has 4000miles and my XTX is 2000.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
2,000-2,200 miles on two Vipers LTXs and no issues. I did add the Yamaha 4th rear wheel kit to both sleds as a preventative measure and I carry the shorter bolt and washers removed to install the kit should one of the outer wheel bearings fail so I can remove it and replace with stock parts if ever required!
Raceit369
- Feb 10, 2014
- WI/MN
4400 miles and my trihub went out. I do have the 4th wheel kit but did not have it on yet when the trihub went out. Wish I would have. Cat/Yamaha dealer up in MI where we were replaced under warranty. The trihub is lighter and stronger with more support than 2 individual wheels. The problem comes in because AC decided to use crappy bearing that are not replaceable and when 1 side goes out, it wears the other side quickly too. Online parts fiche says that the 14 and 15 are replaced with new part numbers. I hope for 16 AC either uses better bearings and/or make them replaceable.
rbell14
1,000 Miles and no Tri-hub issues.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
3400 miles mine was getting stiff. Replaced with 4 wheel kit.
I replaced mine at about 1600 miles the bearings were flat spotted. I believe the conditions you ride in has a lot to do with durability.
The new Tri-hubs have replaceable bearings. At least that's an improvement.
Mr Freeze
- May 26, 2010
- Southwestern No Snow Ontario
- 2014 Viper XTX
Next year is when I expect to see the problem becoming bigger. Just like Cats, it took three years for the failures to become wide spread problem. And now it even bigger each year.
www.jtatv.com
Todd
www.jtatv.com
Todd
Yes I agree except the 12 cats failed in less than 1 season! Was always interesting coming in to dealer on Monday to see the horror!Next year is when I expect to see the problem becoming bigger. Just like Cats, it took three years for the failures to become wide spread problem. And now it even bigger each year.
www.jtatv.com
Todd
- Apr 14, 2003
- Hessel, Michigan
www.jtatv.com
Todd
Your 4 wheel kit is awesome!
I changed mine out after asphalt season.....felt very gritty and wasn't going to trust it out on the trail. Cheap bearings in the tri-hub. After the trip Mark and I had from Minnesota, into Ontario, then Manitoba and back across the top of Minnesota.....I think we lost 5-6 rear wheels in our group.
Mark took care of 3 in one day.....LMAO
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
5000 miles on mine as of now. I have the skid out right now for a new shock, checked the tri-hub and its still in great shape, spins free and no play. I must note that at 3200 miles i added the 2 outside wheels (OSP Kit). Going to keep running it for now.
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
Buddy lost his last weekend , I believe 4500 miles
