yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
There is a stock muffler /header tune but I have no experience with it!!! Maybe next season I'll try it out and see what kinda results...ok, but do you need to run modded exhaust of some type to get that power Increase or is that with a stock muffler?
I imagine it is a huge gain vs stock exhaust manifold like the pm header tunes
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
[QUOTE
You also have the header eh Bob?
I find with the header is doesn't matter what tune i select they all very hit hard!!!lol
No I dont have a header on mine...I am definately thinking about Sandale’s header when they start to sell them.[/QUOTE]
Haven't seen any posts lately about the headers he was testing???
it will definitely be a quality build!!
Imo Mike at Sandals puts out THE nicest exhaust systems in the snowmobile world!
Always superior weld quality and fittement from my experiences...
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
So if I add a header to my 270 SS tune it will be closer to 300?Here is a good example with header and stock exhaust manifold...
With stock exhaust manifold 17lbs make 270
With header 17lbs make 300
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
For the performance muffler header tune that what is claimed!! Dave posted dyno sheets here somewhereSo if I add a header to my 270 SS tune it will be closer to 300?
Stock muffler they claim 285 with header requires 93 octane..
It would be nice e if someone had feedback on header/sm
Of note, TD only reccomends ecotrail as safe for 87 if higher isn't available. Powertrail and any tune above 91 minimum is reccomended.
I see comments that "I never see my knock light". It should be noted that very low levels of knock can happen without triggering the knock light.
IMO, even light deto is never good for an engine and is not worth saving a few bucks over.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I have the quiet trail muffler from hurricane, can get 91 everywhere , not sure about 93
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Is the 3 inch SQ quieter than the 2.5 SQ? I was thinking they may be the same noise level?
Don’t know I don’t believe I’ve heard a 2.5” Super Quiet. I’m guessing Mike at TD could answer that one pretty fast though.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
It takes about 2.5 degress of timing retard to trigger the knock ping counter(knock light) from what I can tell viewing data logs. While zero detonation would always be best Im assuming theres no "harm" being done with minor levels as if there was Im guessing the tuners would have chose .5 or 1 or 1.5 degrees of retard to activate the knock light rather than 2.5Of note, TD only reccomends ecotrail as safe for 87 if higher isn't available. Powertrail and any tune above 91 minimum is reccomended.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
93 for the big tune(300)I have the quiet trail muffler from hurricane, can get 91 everywhere , not sure about 93
91 for 270
Can run 87 on240
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I pretty sure this is the header pm sheet.So if I add a header to my 270 SS tune it will be closer to 300?
It only has 190 horses at 5500.....
I was noticing the other day that I can cruise at 100mph with about 1/3 throttle opening.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
what is going on below 5500 rpm's ?It only has 190 horses at 5500.....![]()
I thought the SS tune works lower ?
How does it get to almost 17 lbs . boost so fast ?
I want to jump knolls like my Apex XTX with the Star suspension upgrade did !
Transfer and some grunt !
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
Want to give an update. Talked with Dave from hurricane and since I live on a lake he talked me into 270 ss pm tune. Haven’t pulled the trigger yet but looks like I’ll be getting that one.He said for the extra 150 or so from the 240 it would be the better bang for the buck. Thanks for all the info. I’ll probably order through thunder since Tim and Terry did my clutching and they’ll have to give me the new setup. Dave was fine with that.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
This is not the ss dyno!!what is going on below 5500 rpm's ?
Dave hasn't released the dyno sheet for ss from what I know!
