Tuned winder throwing code sd-24?
tator
jim falls wi
Sidewinder tuned to 14 lbs roughly 250 hp threw code sd-24. Runs fine. Any ideas?
I looked at my codes chart and an sd-24 doesn't exist.
That code isn't in the 2017 service manual either.
sure you arent confusing with 26 which is a boost leak or turbo bolts most likely?
A lot of sd26 code around here.
Sensor problem? No oil in it! No boost leak . Sled run fine....
It is freezing cold:dunno:
I have this same code and noone knows what it is.. Flashes Code 26 and Code 24 Did have a intake line come off fixed that and still having both Flashing
24 as I see it. Dealer talked to the people who wrote the codes. 24 does not exist. Say it's a cumputer glitch.
Ask the person who created the tune you have.
