tator
Sidewinder tuned to 14 lbs roughly 250 hp threw code sd-24. Runs fine. Any ideas?
Pstn head
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
That code isn't in the 2017 service manual either.Sidewinder tuned to 14 lbs roughly 250 hp threw code sd-24. Runs fine. Any ideas?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
sure you arent confusing with 26 which is a boost leak or turbo bolts most likely?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
A lot of sd26 code around here.
Sensor problem? No oil in it! No boost leak . Sled run fine....
It is freezing cold
It is freezing cold
Warren Silliker
- Feb 23, 2016
- New Brunswick
- 2021 Sidewinder SRX
I have this same code and noone knows what it is.. Flashes Code 26 and Code 24 Did have a intake line come off fixed that and still having both Flashing
tator
Pstn head
So it's nothing ?View attachment 135656
24 as I see it. Dealer talked to the people who wrote the codes. 24 does not exist. Say it's a cumputer glitch.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Ask the person who created the tune you have.
