krm - not sure what sled you are planning to run that combination on but if the sled is not studded and is driven casually that combo should work but just like AXR said be prepared for those stock 2" to wear out quickly - the main problem with the OEM carbides is that the little carbide insert they have is about 1/2 the size of an aftermarket carbide insert and the OEM carbides have no carbide wear pads or hardweld filler on the bar to help increase their durability so they wear out rather quickly. Doesn't mean you can't run them just be prepared to change em out often - on the tuner skis we usually recommend putting an aftermarket (woodys/studboy) 4" carbide on the outside to help get some durability and then run a 4", 6", or 8" on the inside depending on whether the track is studded or not combined with the level of aggressiveness of the rider.
