OPIPE
Hello All,
Do any of you have these on your sled?
Specifically an 05'?
I am looking for the ones your feet basically rest on...the rivet to the top of the tunnel.
Any idea if a set from an 03/04' RX1 will work?
I am not sure if the tunnels are the same.
Any input is helpful
OPIPE
OPIPE
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
they should work
Grimm
Have a look at some of the advertisers on this site. I think "Muffin Works" has what you're looking for.
http://www.muffinworksltd.com/products/supports.html
OPIPE
Thaks Grimm,
But I couldn't find anything for the 05' year?
Still open for sources of tunnel re-inforcments
cheers
OPIPE
cheers
OPIPE
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Yes they will fit. I have them on my 05 Vector. They rivet top & bottom. If I remember correctly the front skid mount hole must be drilled through as the 03 - 04 RX had a different skid. The 05 RX will not fit as it is the same as the Apex.
I have added a picture of my 05 Vector with the 03 - 04 RX1 tunnel reinforcement. if you click on the picture it will enlarge and you will see a white dot near the front of the reinforcement. That is the mounting hole for the RX1 skid. It does not interfere with any thing as the mount for the vector is quite a bit further ahead.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
OPIPE said:Thaks Grimm,
cheers
OPIPE
Models years '05 and older use a different style of running board grips. Our designs only accomodate the grip styles found on '06 and newer models.
- 39K
