Jensen
Hi, got a turbo warrior(mc-xpress). Was thinking about getting nos. Have any body got pictures of installing the nos? And where does the nos bottle go in the engine room..
Jensen
Jensen
- Apr 14, 2003
- Hessel, Michigan
yamahajunkie
thats how you run it with the k&n's? dont they have an injector that goes in the filter? very interested, just trying to get info before i spend the cash. do you get any oil out of crankcase filter?
yamahajunkie
is the first pic with k&ns a dual stage? or is one fuel and one no2? any reply would be great.
TURBO TIME
TURBO TIME
WOW that is sweet!! What kind of HP you have??!!
TURBO TIME
ABOUT 320HP
- Apr 14, 2003
- Hessel, Michigan
Yamahajunkie - Sorry I didn't get back to you sooner.
The first pick is my own nitrous setup, and is injected into the carb boots, both fuel and nitrous. No oil consumption at all.
Second one is Holtzman's nitrous system, and the fuel is injected into the boots, and the nitrous is injected into the airbox. I just put these pics up so you had 2 versions of mounting the bottle.
yamahajunkie
thanks for the reply NOS-PRO!! is that 1st pic all NOS parts? did you get it as a kit? does it have a fuel pump. looking at all options (custom) and package (holtzman/ boss noss) thanks for your time. junkie
- Apr 14, 2003
- Hessel, Michigan
Hey Junkie - I mounted the nitrous kit from parts from Nitrous Oxide Systems in California, and yes, that is everything including a fuel pump.
2nd is Holtzman's, and the solonoids are hidden for a clean look.
hugetime1
would a set up with nos and a turbo, be a good reliable trail sled??????
If set up right yes both would! But i would say Nos alittle more. Lots less stuff to go wrong!
Skydog
Skydog
kip
- Feb 22, 2004
turbo time.... what happens when you are underfull boost and you hit the n2o ..... i have a boondocker system and it does not allow for proper fuel delivery while under boost.... if you have done something different and it works, would like to know..... kip
Jensen
Does anybody have a picture of a nos bottle in the engine room WITH TURBO.
