![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I sprayed every clamp on it. Nothing for leaks. This BOV leaks like crazy. Even at 10 pounds. I can try tightening the top but I’m guessing it’s junk. Not sure what’s going on but this is NOT the first I have heard on this valve. It does not have a great reputation. Guessing most don’t even test them for leaking. They buy it and think well TD and Hurricane sell them they must be good right.
DooZ
Sounds like a bad one...can you return? I like what tommcat offers, but $300+?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Interesting, I've never had leaks like that on mine. Doesn't seem right. Were is it leaking from? Looks to be coming from everywhere.
I tighten all the parts though too. Usually the banjo bolt is loose along with the threaded connections that thread into the body of the unit.
NYTurbo
I've pressure tested a lot of them and never seen one leak like that.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
It was leaking from the top seam. Where are we tightening this thing? And why if its brand new would it need to be tightened? Poor manufacturing.Interesting, I've never had leaks like that on mine. Doesn't seem right. Were is it leaking from? Looks to be coming from everywhere.
![Inkedupgraded-blow-off-valve-yamaha-sidewinder-arctic-cat_LI.jpg Inkedupgraded-blow-off-valve-yamaha-sidewinder-arctic-cat_LI.jpg](https://ty4stroke.com/data/attachments/121/121574-9d68e91ff59008c897317bfc2d967876.jpg)
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Nope I bought this thing back last spring.Sounds like a bad one...can you return? I like what tommcat offers, but $300+?
Todd Beenen
Respons might be on the pricey side , but it’s a quality piece that works well.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Going to try and tighten it I guess. Otherwise Im going with the one I posted above.. Made in USA and the company has a good rep.
Turbo XS
Turbo XS
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I see tommcat offers two different BOV on his site..Respons might be on the pricey side , but it’s a quality piece that works well.
KnappAttack
- Feb 19, 2004
- Welch MN
It was leaking from the top seam. Where are we tightening this thing? And why if its brand new would it need to be tightened? Poor manufacturing. View attachment 163837
All three joints and the top banjo bolt. They are not tight from the factory. Take it apart and check all the 0-rings too, maybe some debris is keeping the o-rings from sealing. Prolly made in China or Taiwan so I've never seen one come thru with any of the nipples or joints tight ever. (The nipples also screw into the body as they are made in different sizes). Just like the Cat/Yamaha sled were putting them on, you need to go thru the aftermarket parts to perfect them too.
Once you get it sealed up it will be just fine and is actually a good piece.
Todd Beenen
1100 & 998I see tommcat offers two different BOV on his site..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Seeing two for the 998 > $250 or $3501100 & 998
Todd Beenen
Ones a hybrid, no idea on the difference.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Same company makes both. Reading about the company now.Ones a hybrid, no idea on the difference.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
Looks like I am cheaper to buy it direct. However I have zero idea how to set it up lol
