rx1 fern
got my ulmer clutch kit but was wondering how do you put the weights in it for adding the 1 gram weight. .this is for the 2015 viper ltx.came with helix and two springs .it slides in the holes but how does it stay in place .thanks for the help
1 gram is 1 washer... take the tool that he gave you and the directions that came with it and read. It pretty simple once you look at the weights.
rx1 fern
just talked to allen and he said just take a hammer and hammer the aluminun down .thank you .instructions didn't say anything about the aluminum weight part .
You have an old school kit?? Or Super tips... you dont just hammer the supertips.
rx1 fern
its the ulmer kit which comes with yamaha weights and aluminum 1 gram weights that you put in the holes and hammer the other side so it stays in it
rx1 fern
also i didn't get a tool .what tool you mean
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
rx1 fern
my clutch kit came with factory yamaha weights with the holes empty ,so i can add weight .The aluminum 1 gram washers is for weight .it also came with a red spring and helix for the secondary and a yamaha spring for primary .is that what you have on yours mr.sled
yamabob
- Sep 13, 2004
- newhampshire
- sleddless
im looking at a 2016 ltx le with ulmer clutch kit not shure what difference its going to make over stock also has a an intake ?? not shure about that VFORCE REEDS maybe not shure
