Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I think 41/37 is not really agressif for tune sled. I am running that now because i am light studded
I don't break belt anymore Did i just "jinx" myself?
lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Depends on the tune for sure.....But with early spool Hurricane you can pull alot of helix down low, TOTAL opposite of what I experienced last yr.I think 41/37 is not really agressif for tune sled. I am running that now because i am light studded
I am not broken belt... Did i just "jinx" myselflol
BTW if anyone looking for STMs, shoot me a PM.
Dan
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
There is some primary weight profile now that can help a lot spooling the turbo
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
Curious on what the max amount of washers you can add to each side of the stm weights? I know you don't need the rubber with 4 washers is it possible to add 5 or 6 to one side and a tungsten on the other side? I'm going back to stock secondary for now and the powertrail is rated at 14.7 lbs looking at Ulmers clutching sheet he says a tungsten and 4 washers for 14lbs and the same for 16 but I believe this is based off EVO flashes and their target rpms are 9150 to 9450 I believe. I wanna be between 8700 and 9000 so I was thinking either 2 washers added to the 4 in the tip or just another tungsten. Just don't want my rpms too low. Btw anyone who's running a stock sidewinder and want to buy a slightly used dalton 33/35 helix less than 100 miles and orange spring shot me a message and we can talk
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
4 washers max, if your running the stock helix you'll want 2 tungstens in the tip and 4 washers in the heel. That should put you close.
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
Ok sounds good brother thanks again for all your help. When I get the extra funds I'm gonna get the stage 2 and hopefully be satisfied with everything.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
4 washers max, no 0 ring....
below 4 washers use 0ring first, then washers overtop.
Nice to work with.
Nice to work with.
