Although physically the same, the Cat ECU uses coded ID number related to the VIN number. Still may work though. The other thing to watch out for is the different models of sleds use different speedometer calibrations based on track driver size. So you'll want to find one from a sled that uses the same size drivers as your sled.
For used one, you might try Barn of Parts.
