Darren Betker
Please someone chime in here and tell me there is a company out there that sells a oil filter relocation kit!!! somewhere in the nose cone preferably. Taking this sled apart just to swap a filter is absolutely idiotic. Yamaha wtf were u thinking!!
HighSpeedLowDrag
There are kits to do that but I don't recommend it. http://www.benderracing.com/Oil_Filter_Relocator_Kit_p/ofrk.htm
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
It's not that bid a deal, bring it here I'll change it for you.
HighSpeedLowDrag
The remote mounted filter takes it from a protected area and adds multiple possible failure points and interference with other components in order to place it in an exposed (the nose cone is as protective as a milk jug) area which used to be good storage. No thanks.
I recommend moving the voltage regulator to the inside of the front castings as well.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
It's a 1/2 hour job,Please someone chime in here and tell me there is a company out there that sells a oil filter relocation kit!!! somewhere in the nose cone preferably. Taking this sled apart just to swap a filter is absolutely idiotic. Yamaha wtf were u thinking!!
bigdog_mike
WOW...ruff crowd here...i have the Ulmer oil relocation kit that he use to offer and absolutely no issues with it being in the nose of my Apex, it was installed in 2006 after the first oil change and have no issues with the protect of the nose piece, unless you ram a stump which would damage alot more then the oil filter I would install then kit there, also with the nose pan removed it makes for a clean oil filter change...
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Here is what I do. Follow the manual and replace the filter every 12,000 miles... of course I have 18,000 miles and have put in 3 filters so I did not follow to the letter but still not every 2500 mi oil change.
500mi filter 1... 7500 mi filter2...15,000 filter3......
gitrdun
You need to experience a donuts and Y pipes change, then you'll actually look forward to doing an oil filter change.
Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
I change my oil once a year and while it is apart I do all my off season maintenance. No big deal listen to tunes have a couple brown pops and before you know it your done!! Easy peasy lemon squeezy.
Darren Betker
Thanx Big dog. Thats exactly what i will do. You guys can change a filter when ever you want .mine gets done every year no matter the kms. Cheap insurance. So sorry for whinning. I guess some people take offence to people asking for help.
Some of you boys need to take step back and play nice. Please take a minute to clean up your posts.
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Like snowman says, every 12,000 mi..
CaptCaper
- Jan 1, 2007
- Northern N.H.
There is a step by step process in a sticky here. Not bad if you follow it.. you'll want to get down in there for your battery someday or to check wiring or relay issues.. so best to learn now.. if your worried wait until the end of the season for the filter change.. oh if the battery is old ..cheap enough to change it while doing the filter..
Darren Betker
Luckly the battery was just changed before i bought it.....a month ago......so i dont have to worry about it. I just dont get why in the 13 plus years this sled has been available, yamaha hasnt bowed to publuc demand and put this relocation kit as OEM . Oh well. Im doing it asap. Wish i had a yamaha dealer in my city but i will use yamaha filters and i will be changing them every year no matter of kms. Learned along time ago that changing oil sooner then later is always good medicine.
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Just to clarify my post....I change the oil every 2500 miles I just change the filter every 7,500 miles. I think the reason Yamaha has not changed anything is they recommend every 12,000 miles for the filter and for most people this is many seasons.... so why add the weight or cost?
