Have anyone seen a valve failure like this before?
It's a turbo's worst nightmare......
Does this happen often out in the big world?
gunnerthesnowman
jhlarsen said:Have anyone seen a valve failure like this before?
Yes i have seen it , i had it happen , from the looks of it you are lucky , mine took the valve seat and head , very costly , head was ported and had over size valves.
Mine was caused by being very lean on top end under boost .
gunnerthesnowman said:Yes i have seen it , i had it happen , from the looks of it you are lucky , mine took the valve seat and head , very costly , head was ported and had over size valves.
I was wondering if this would be avoided with aftermarket valves, but maybe not....?
I was running slow, no boost at the time.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
head is on costly piece to replace... had to do this this summer..... ouch$$$$$
Me too, I ended up by a used engine for cheaper than I could buy a bare cylinder head. Dealer was even giving me the head near cost. Engine I brought even came with wiring harness, starter, brain box.
Do you have any timing advance control? If you wern't under boost one reason I can see that happening is if you have some major timing advance in your low and mid range.
zross1 said:Do you have any timing advance control? If you wern't under boost one reason I can see that happening is if you have some major timing advance in your low and mid range.
I'm running rb3 with a map from dave at hurricane.
But were i was in the map at the time, i don't think it's to much advance.
But i will check in to that. Thanks for the heads up
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
i think its from the carboned up valve.carbon produces heat and i think thats what caused thatjhlarsen said:zross1 said:Do you have any timing advance control? If you wern't under boost one reason I can see that happening is if you have some major timing advance in your low and mid range.
mike3577 said:i think its from the carboned up valve.carbon produces heat and i think thats what caused thatjhlarsen said:zross1 said:Do you have any timing advance control? If you wern't under boost one reason I can see that happening is if you have some major timing advance in your low and mid range.
The carbon build up may be form the long drive down from the mountain..
gunnerthesnowman
jhlarsen said:mike3577 said:i think its from the carboned up valve.carbon produces heat and i think thats what caused thatjhlarsen said:zross1 said:Do you have any timing advance control? If you wern't under boost one reason I can see that happening is if you have some major timing advance in your low and mid range.
Thats what i was thinking !
Ted Jannetty
This is a severely overheated exhaust valve, not enough timing, Restricted exhaust system or header, too small and exhaust housing, too lean a mixture can all lead to this.
Ted.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Extensive cabon buildup to the point the valve didn't close anymore and the valve hit the piston.
What does your piston look like?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
what if deto gods showed up and broke a piston part and that would have hit valve on closing event.....
just a though...
just a though...
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Actually it's one of the three small valves... so it's an intake valve and not an exhaust valve.
Still can be caused by thermal fatigue...
How was the valve lash? Excessive clearance causing pounding?
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
Its an exhaust valve.
- 41K
