1Gunner
A buddy of mine just purchased an 06 Vector GT. Sweet looking sled!!!
He'd asked me what I would recommend for studding, and I suggested 144 down the center using Woodies double backers alternated with singles. His dealer refused to install them..... claiming "the track would balloon with all that weight down the center", causing damage....
so they only installed 96 with single backers, claiming that's all he needs.
Basic rule of thumb... 1 stud per 1 HP, so 144 should be just fine.
Will 144 down the center cause problems?
Is 96 really enough?
Will studding the outside cause premature track failure (it has for me in the past)?
Thanks for any and all feedback!!
STORM-CHASER
flyingpig
Nice! Might consider that!
twomorestrokes
144 down the center will work great on the Vector. I also have the double/ single pattern and it has been great for 1000 miles of hard riding.
I think 1 stud per hp applies more to the two strokes because the fours have quite a bit more low end torque. I think they should have at least 144 so they'll hold up. If you ride aggressively you are asking for stud and track problems by understuding. Just my opinion.
I'll never stud the outside of the track again.
Flipper
- Oct 31, 2003
- Ottawa, ON
- 2018 SideWinder LTX LE 50th
- Ottawa
I have 144 1325's down the middle and over 8000 km's on my 05 Vector with no issues.
Groomerdriver
FWIW - I have 144 singles and are using the classic 144 pattern that includes the outside of the track. Only have 700 miles, but so far so good. In hindsight, should have went with 120 down the middle.
1Gunner
Has anyone seen or heard of any problem issues regarding 144 studs down the middle?
Thanks!
Thanks!
twomorestrokes
I haven't. There are quite a few members that use more than 144 with no issues.
Tfin
I have 120 down the center in Woody's "Aggressive" pattern. I have 1671 miles of aggressive (go figure) riding and haven't had a single problem yet.
twomorestrokes
I suppose you might experience a problem at higher speeds...maybe 250 mph :wink: ...
1Gunner
twomorestrokes said:I suppose you might experience a problem at higher speeds...maybe 250 mph :wink: ...
That's speedo speed, right?...... :wink:
I guess he'll have to put on whatever dopey the dealer will support, even if it isn't what's safely optimum!
If he ever had any warrantee track or skid related issue...and he had put what folks in here have used "tried and true".... dopey the dealer would just blame $hite on the stud pattern....
gOOsemann
192 right down the middle. all double backers. no probs whatsoever.
- 147K
