yamaha06
Well I was up north this weekend riding and it was cold out, -13F to be exact. Well today the temperature did a 180 and the temperature was 34F and the viper didn't seem to like that! I don't know if anyone else has noticed this but with it being warm out the engine seemed to have a different noise when cruising around, the trails were so rough and slick with the packy snow I couldn't go any faster then 13-20mph. The engine temps were getting up there so I would stop every once and a while and let it cool down. In the end I ended up coming home early. Have you guys noticed your engine sounds different when the temps are warmer outside?
weasel33
Only when I stopped and let it idle for a minute or two did the temp go above 170 degrees
Pstn head
I was in muskoka today and yesterday. Today was around +1c, yesterday the sled ran better yes but by no means was it running bad today at +1c. Is it possible you were running roads with low snow and maybe overheating an d the sled went into limp mode ?
yamaha06
I didn't see any codes or engine lights, the engine temps were around 85 when I was riding today, couldn't get to much speed since I had a passenger and the trails were rough. But just putting around the engine seemed to have a different tone to it compared to when it was cold, but if I got onto the throttle it sounded good, maybe it didn't like being driven around at such low speeds haha. I was riding around the south river area, but left once it started to drizzle.
Mine doesnt start as well when its warm out. Still starts but cranks a bit. -10F it start almost instantly almost like a explosion. Just a observation I can live with it.
Yamaha 06 I bet you were hearing those stupid little bumps on track. Is very noticable if trails are setup.
Curtis Chambers
- Nov 19, 2014
- 2015 SRViper R-tx-Le
I was lining up track today in my garage running sled for a bit about plus 1 c and the sled was sputtering and running like crape temp light came on pretty fast. I have a feeling they get warm real quicke without proper conditions. I hope its not this sensitive on trail around 0 c.It was running a while though.
I have never seen temp light except the startup warning. Was your fan running? That fan and radiator is bigger than many cars!
Curtis Chambers
- Nov 19, 2014
Yes it was I can hear it even when I shut it down ,I hope I was just running it to long. I just find it kind of odd it it came on and started sputtering , starting was odd after that too. Kinda nervous goin on a trip this weekend will see what happens. Father in law bought new vector and his is not doing well either.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Is it possible that you cracked your helmet open while riding in warmer temps? Our wore a thinner balaclava?
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Was in my garage today fiddling with the sled and had trouble getting it started once. Had to crank it 4 times and the last time I gave it a shot of fuel to get it running. Is this the dreaded hot start issue????
Started it a couple times after and it didn't start as usual and was not running like when outside.
At the cabin in -20 it started and ran perfect every time.
This sled could be like myself...likes the cold and snow better then warm weather. Lol!!
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Ran last spring in temps as high as 8-10C with no problems on hard packed trails, if you can keep speeds up a bit the rad seems to handle it .
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
In mid November we took a ride on about 2 foot of new wet heavy snow and the temperature was 35F to 40F. The sleds got a serious workout in that heavy snow and never had overheated issues. No hot starting issues either. Matter of fact they didn't miss a beat all day. However we did have driver overheating issues
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
One thing I did notice with the sled was that sometimes the temp would creep up pretty fast to about 92-94 degrees C and the fan cut in. This was with good conditions but I was just riding a bit slower at a constant speed. When I noticed the temp was higher I just cracked the flipper for literally a couple seconds and the temp dropped like a stone back to 71-74.
Joey P
- Dec 12, 2014
- minocqua
- APEX XTX SR Viper XTX
i rod e my turboed viper all weekend here and it was 35f out and it didnt seem to care at all it stayed the same right in the middleWell I was up north this weekend riding and it was cold out, -13F to be exact. Well today the temperature did a 180 and the temperature was 34F and the viper didn't seem to like that! I don't know if anyone else has noticed this but with it being warm out the engine seemed to have a different noise when cruising around, the trails were so rough and slick with the packy snow I couldn't go any faster then 13-20mph. The engine temps were getting up there so I would stop every once and a while and let it cool down. In the end I ended up coming home early. Have you guys noticed your engine sounds different when the temps are warmer outside?
yamaha06
Ya I don't know, the engine sounded different on all the surfaces I drove on, wore the same helmet. It's hard to explain how it sounded, I should of took a video clip. I will get it on the snowmobile stand and run it to see if it sounds any different then it did yesterday.
