I have a viper 2015 xtx 141 LE whit PC track.
My current setup is:
Super tip 50g
Primary spring O-P-O
8dn
Dalton 46/40 helix
Stock spring and Dalton red spring.
I have read, "Clutching to the cheap"
I have some question about the secondary clutch. I have tested the Dalton red in 6-1 and it work OK, but whit the standard pink set in 3-3 i fel that it´s more pull from low end, i don’t se some big change in top speed between the springs, but the snowmobile doesn’t go so fast 120-130km/. "Dead end" comes in 115-120km/h.
I wonder if it can be some coil binding. is the Dalton helix cut for prevent coilbindning ?
Can i measure the depth of the two helix and see if they have the same from top to bottom.
My thought was to put in the stock helix whit stock spring and see where the helix is starting on the buttons, then install the Dalton helix and se if the start are at the same position. If it´s don’t start at the same position can a shim the helix out. is this the right way to go?
Another question is if the helix ramp should go hole way out when is it full shift.
Or should i just order the big venom secondary spring that seems to be god according to the "clutching to the cheap"
I have seen that it´s the G-W-G spring in the COTC kit, this spring has almost the same finish rate as O-P-O but longer, is it a ide to change primary spring and put some washers in?
i think a have Y-G-Y 40-123 89,4mm long. Longer that O-P-O but 0,4mm shorter than GWG, don’t the same finish but the only it will do is that i must take away some weight, is it any ide to test the YGY?
Super tip 50g
8dn
Dalton 46/40 helix
